Protecting Plastic Pipes Against Freezing
HeatingHelp
HeatingHelp Administrator Posts: 718
edited December 2021 in THE MAIN WALL
imageProtecting Plastic Pipes Against Freezing
The Plastics Pipe Institute, Inc. (PPI), has published a new Technical Note related to the protection of plastic pressure piping materials against freezing. PPI is the major trade association representing the plastic pipe industry.
Read the full story here
  • Steamfighter49
    Steamfighter49 Member Posts: 25
    I take it I must be a member in order to see? Not real helpful.
    EBEBRATT-Ed Member Posts: 19,621
    I would like to know how to successfully insulate pex tubing. Fiberglass rigid pipe insulation doesn't work well with flex pipe. Armaflex in most cased is the wrong ID ..it doesn't fit the pipe sugly enough especially in chilled water applications to prevent condensation so what else is there?????
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    @Steamfighter49, both links are working for me. I'm not a member and it's not asking me to join. What are you seeing?
    Retired and loving it.
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    Here's a link to the report (no membership required): https://plasticpipe.org/tn-65
    President
    HeatingHelp.com
    HomerJSmith
    pecmsg Member Posts: 6,781
    PEX is like refrigeration tubing you need the OD of the pipe. 1/2" requires 5/5" armorflex, 3/4" requires 7/8" Armorflex.
