Steam gods north of Boston, MA
I'm not sure this is the appropriate place to post, but I am looking to have a new steam boiler installed. My current boiler is a gas Burnham that is just over 10 years old with a hole in the top. The previous boiler was over 40 years old when it was replaced. I have learned a lot recently reading these forums and read The Lost Art Of Steam Heating. For example I learned I have no main vents which is bad. It's a two pipe vented system and look exactly like the picture on page 125 of LAOSH including the huge amount of return piping (on top of my basement floor) I'd love to have someone with real knowledge of steam look at my system, make any required changes and install a new boiler. Thanks in advance!
    mattmia2 Member Posts: 17,483
    @New England SteamWorks . I think there is another one in Boston too.
    Jamie Hall Member Posts: 27,584
    Depending on exactly where "north of Boston" is you might persuade @Charlie from wmass to go that far. Ryan -- @New England SteamWorks is actually in Providence, and I know he works in the Boston area and is certainly one of the best around, but I'm not sure he's any too keen on going "north of Boston"... worth a try, though.
  • I-95 & I-495 North, no problem. I-93 North (Essex County) not happening.
    newenglandsteamworks.com
    STEVEusaPAmattmia2kcopp
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,430
    Anywhere anytime, if I can fit it in my schedule. Talking February for any new projects. But happy to discuss.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • GlitchZ
    GlitchZ Member Posts: 3
    Thanks for the response New England Steamworks. Your work looks amazing! Unfortunately, I am in Haverhill way up 495 North and it will be quite a hike from Providence. I did fill out your web form, paperwork and send pics of everything this afternoon.
  • GlitchZ
    @Charlie from wmass thanks the the response.February is far off unless I can get my existing boiler to hobble along but I will call you on Monday or whenever is good for you to discuss.
    If it were mine i would...do it myself. but failing that, i would patch it up well enough to wait for one of the 2 above.
