Radiant under pool, indoors
MBuck
MBuck Member Posts: 1
I am planning to put a 21’ x 50’ x 4’ vinyl swimming pool recessed into the floor of my Indoor dock diving pool. Formed with concrete and them set the pool inside the recessed area. I would make this area its own zone. I would like to use this exclusively to heat the pool. I do use a solar cover overnight and when not in use, but the pool would be uncovered much of the day 6 days a week. 8-10 hours.
i will also have radiant floor heating in the remaining part of the building. 140’ x 60’ x 12’.
My questions are: is this an energy efficient  option, and where would I add a thermometer/thermostat to control the pool water temperature?
Thank you!
Marie
  • Zman
    Zman Member Posts: 7,614
    Since you need to constantly filter the water anyway, the most effective to heat a pool is to put a heat pump, boiler, or heat exchanger in that loop.
    It is possible to heat an indoor pool via radiant tubes, it would definitely be the "hard way" with no real up side.
    Albert Einstein
    hot_rod Member Posts: 27,703
    With indoor pools, if the room is heated the pool load is reasonable for radiant. I tried a small outdoor swim spa with radiant and there is just not enough surface area to cover the load. It also depends on expectations for temperature recovery
    De-humidification is critical with inside open pools
  • Paul Pollets
    Paul Pollets Member Posts: 3,672
    I've heated the pool deck with radiant loops a few times, but never the pool itself. There wouldn't be enough BTU's available to make a difference. As Zman said, pool heating is done with a heat exchanger, a dedicated boiler or a heat pump. Indoor pools require pool dehumidification systems.
