Embassy Industries Onex Combination Boiler - OX160C
may7day
Member Posts: 17
I Have 1 zone in my home and I'm having heating issues with my bedrooms. The heat works in the Living Room & Den but the pipes are cold in the 3 bedrooms and wont allow heat to pass through. Shower and faucet on the same floor as the bedroom work fine. Any clue at what this could be? This only came to light the last 2 days.
2nd floor bedrooms, yes?
what's the boiler pressure?
you need enough pressure to keep water upstairs, like 12 - 15 psi,
if pressure is low, you're likely air locked up there, and need bleeding, or purging, or both,
pictures at the boiler, and of the upstairs radiation, and we can go from there.
known to beat dead horses1 -
My PSI has been acting up the last few months but it loves reaching 30. PSI never drops below 20. I just bleed all the water from my house and the boiler. reintroduced new water into the home. Same problem.0
Not that I can remember(heat). I recently changed the expansion tank in my boiler also. How to I fix the air lock in the upstairs?0
Depends on how your system is piped. Do you have baseboard, cast iron radiators, heated floors?0
remember,
pictures save us thousands of wordsknown to beat dead horses0
- 120 Geothermal
- 169 Indoor-Air Quality
