Boiler cleaning
budheavy
Member Posts: 1
How often should you have an oil fired boiler cleaned
At least every year.Br. Jamie, osb
Depends on the boiler and what the manufacturer recommends. My triple pass, double filtration, set up perfectly only gets cleaned about every 4 years, filters & nozzle when the vacuum gauge says so.
I do stick the analyzer on it every year just to see where I'm at.There was an error rendering this rich post.
STEVEusaPA said:Depends on the boiler and what the manufacturer recommends. My triple pass, double filtration, set up perfectly only gets cleaned about every 4 years, filters & nozzle when the vacuum gauge says so. I do stick the analyzer on it every year just to see where I'm at.
I haven't touched mine in about 3 years but need some motivation. If my wife told me there were Mallomars, I'd be there in a heartbeat.
1
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
