Pennco steam boiler overfills then shuts off
Kunkun_20
Kunkun_20 Member Posts: 1
edited November 2021 in Gas Heating
hello need help , I have a pennco steam boiler , it overfills to the point some water comes out of the radiator. Also at the same time it keeps turning off . Any idea what might be causing this?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    Bypass though the boiler feed valves .. Manual or auto . Anything else connected to boiler like for hot water ?
    Jamie Hall Member Posts: 27,582
    It will turn off because the water rising in the system increases the pressure, which turn the pressuretrol off. Good thing, too.
    EBEBRATT-Ed Member Posts: 20,481
    If you have a tankless water heater coil in the boiler it may have sprung a leak or the manual feed valve is leaking by or if you have an automatic water feeder that could be leaking by
