Navien CH-240 ASME Boiler/water heater combi
fishawk25
Member Posts: 2
I no longer need to use the boiler portion for heat and want to disconnect so it no longer heats that portion, but continue to use the DWH. I disconnected the Thermostats for the board and that appears to do the trick. is there anything else I need to disconnect before I drain, disconnect and cap the pipes to the floor heat?
thanks Ironman. so I have to leave water in the loop but I can just loop the heated supply back in the return pipe and eliminate the floor heaters loops?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
