Wood burning furnace help me
skavanau
Member Posts: 1
Just bought a house that has a wood burning furnace. No Manual.. no instructions. I need to have someone talk me thru the process of using this furnace. Ive called around (VA) and they act like I have 3 heads...Could someone PLEASE help me. I put wood in...turned on the humidifier...turned on the fan.. flue is good.. but it doesn't get hot upstairs..it blows cool air...Thank you for any help...
Is this furnace a YUKON wood furnace??0
Post some pictures of the flue, furnace, ductwork etc. Stand back so we can see what you see.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Is it wood only or does it also have an oil or propane burner?0
Nowhere does the OP say he lites the fire!skavanau said:Just bought a house that has a wood burning furnace. No Manual.. no instructions. I need to have someone talk me thru the process of using this furnace. Ive called around (VA) and they act like I have 3 heads...Could someone PLEASE help me. I put wood in...turned on the humidifier...turned on the fan.. flue is good.. but it doesn't get hot upstairs..it blows cool air...Thank you for any help...
I'm wondering if the wood is actually burning?
Won't use too much wood that way, but won't get any heat either
Just sayin'
1 -
I would also add a quality CO detector in the home that has a wood burning appliance like that.Bob "hot rod" Rohr
Living the hydronic dream0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
