Old Colonial - a Lot of Rooms - How many Zones?
Alan_Koziol
Alan_Koziol Member Posts: 10
edited October 2021 in Gas Heating
Evening Everyone,
Started putting my current residence back to 2 family. An Old Colonial, 2 Primary Floors and a lot of Rooms. (And Doors). :( Basically, both floors have all rooms connected.
Each floor is a Single Zone - FHW Baseboard heat, looped around the outside perimeter walls. (Except for the kitchen - Under-Counter kick space heater.
1st Floor - You have Kitchen, 1/2 bath (hopefully becoming a Full), Dining room, Living room & Den. There is another room, but I am considering that to be a different zone from this post.
Originally, the thermostat was situated in the Dining room (which has a South window), so I believe that was causing false readings and a cooler 1st Floor.
The Kitchen has a hallway, just under 6' from the door to the Living Room & Den. That is where I relocated the thermostat.
Considering breaking the 1st Floor zone to have the Living room & Den as its own thermostat zone. Only have to close the door between Kitchen and Living room.
The Kitchen thermostat would be responsible for the Dining room, Kitchen and 1/2 bath.
Similar approach for the upstairs zone conversion. So, I would be going from 2 to 4 zones.
Am I going in the right direction?
Any feedback greatly appreciated.
Thank You
Be Safe.
    EBEBRATT-Ed Member Posts: 20,481
    How does it heat the way it is? Only you can decide. 4 zones sounds like plenty.
    Thermostats in a kitchen is usually not done unless on it's own zone a cooking will through them off
  • Alan_Koziol
    Hi Ebebratt,
    I agree with your statement about the thermostat and kitchen.... but here's why I went that route. My location is more central in relation to the floor layout. Even though it is in the kitchen, I work during the day. The other factor(s) were based on how my house generates false readings. The thermostat's original location was in a room that had window facing South. Thermostat could read 70F actual was closer to 66F.
  • Alan_Koziol
    Ebebratt,
    Now that it's getting colder now and I'm indoors cooking more I thought about our conversation about thermostat location. I have been watching how it registers while cooking aka using the oven... The thermostat has NOT gone above its setting... I believe it's from all the avenues the air has to travel in my residence that it remains stable from circulating between the 5 rooms.
    Just my opinion, I could be wrong as to why it is doing what it is OR I just lucked out.
    @Alan_Koziol
    The general rule is no stats in kitchens. There are other rules of thumb like no stats on an outside wall. And no return air out of a bathroom (for obvious reasons).
    If it works it works
  • JakeCK
    JakeCK Member Posts: 1,502
    @Alan_Koziol
    LOL
