Help needed to troubleshoot boiler
Treebeard
Member, Email Confirmation Posts: 18
Old MZ boiler. Mechanic changed gas valve and it works well except it is still failing to stay lit. The flame comes on for a few moments (about a second). Any ideas what needs replacing now?
This is a condensing boiler which has been maintained for many years. The water is in a sealed loop, and the pressure is correct. The boiler will work for hours or days without a problem and then it will flame-out. The mechanic said it was a bad gas valve and replaced it. Weeks later the boiler is doing the same thing. No strange sounds, just ignites the gas, then the flame goes out.0
Where are you located? Your model may not be sold in the US.
It is likely the boiler is not "proving" the flame. It also sounds like the "mechanic" is a parts changer rather than a troubleshooter. That can be an expensive road. Was a combustion analysis performed when the gas valve was changed?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
