UMW upgrading 90 year old steam lines
University of Mary Washinton, Fredericksburg VA is replacing all of the underground steam lines that were installed as part of the campus expansion performed by the Public Works Administration in the 1930s.
Currently, the project is installing temporary above ground lines since the underground service lines (including water) replacement is schedule to take 2 years. The scale of this effort alone is pretty impressive.
Wow. I hope it goes smooth & safely for them. It looks like a big job!0
Yes, quiet large project but the construct company seems very organized. This article discusses the activities for the current phase with panned completion in October. I’d say that’s pretty optimistic given it took them 3 months to set up about 1/4 mile of temporary lines.0
Unfortunately replacement of 90 plus year old district heating and water lines is expensive. Especially so when the piping has to be run in the same plain and service has to be provided for the institution.
Hope the design engineers figured out how the job should be done and the contractor knows the work.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron1 -
Found out that the steam tunnel restorations was not part of a long term plan but grew out of a pretty big failure. I watched this building being renovated along with some pretty large steam tunnels work over the past few years but figured the building work was part of planned restoration.https://www.fredericksburg.com/news/local/willard-hall-closed-after-steam-tunnel-rupture/article_da2e2e04-29ad-56cd-9203-b34b845c47b8.amp.html
I imagine this is like the tip of the iceberg of what NYC deals with annually.0 -
I can't give you the exact timetable for the work that was done at the VA here in Butler, Pa but, a number of years ago, they replaced most of the steam heating distribution piping that was underground. A few years later it all had to be redone again because as I understand it, they used the wrong type insulation on the buried piping. I guess that you don't have to be too careful when you are spending the tax payers money.0
That's what happens when you hire the lowest bidder and they subcontract and supervise the lowest bidders.
We have a lot of around 100 year old steam tunnels at the University of Michigan and they are constantly digging up and rebuilding collapsing sections.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
