Corrosion inhibitor in an aerosol can?
sunlight33
Member Posts: 378
Does anyone know where I can purchase online a boiler treatment in aerosol form that I can simply inject into a drain? I did a google search but some vendors do no sell to consumers.
I don't know of the product you are looking for. What is the application? What products have you found?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
https://www.rhomarwater.com/Hydronic_Treatment-Boiler_Treatment_Kit_Aerosols.htmlZman said:I don't know of the product you are looking for. What is the application? What products have you found?
Does the connector fit male garden hose thread?kcopp said:0 -
yes
Received the X100 today, instruction says one can treats system of 25 gallons, mine has less than 10 gallons, will it do any harm to dose the whole can?0
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
