Low-Loss Header ASME or Non-ASME
space
space Member Posts: 3
edited June 2021 in THE MAIN WALL
Hi, when does a low-loss header need to be ASME rated? Thanks
  • dopey27177
    dopey27177 Member Posts: 916
    Typically only when ASME items are specified, government work and when you liability insurance covers errors of omission, errors of commission and the insurance company does not have qualified inspectors.
    Jake
    EBEBRATT-Ed Member Posts: 20,119
    Only if ASME considers it a pressure vessel. The size may have something to do with it. That is the reason large water heater are 119 gallons and not 120 gallons
    Rich_49
  • Zman
    Zman Member Posts: 7,611
    It is dictated by the BTU rating and design pressure of the system.
    Some more details as well as the local codes would help answer the question.
    Albert Einstein
  • space
    edited June 2021
    Thanks everyone for the replies
    Building is in Saskatchewan Canada, which adopts the National Building Code.
    2 condensing boilers (input = 280 MBH each).
    Typical boiler pressure (between 12 - 30 PSI).
    Low-loss header flow rate is 132 GPM.
    Please let me know if you need any more info and thanks again for all the help
  • Dave T_2
    Dave T_2 Member Posts: 64
    edited June 2021
    you can always build a low loss header with fittings for multiple boiler injection. A 3" header will give you 132 gpm and each boiler will need 2 - 3x1.25 closely spaced tees.
    I would question why you need 132 gpm through the header? Sounds high considering the total input.
  • space
    Closely spaced tees will work.
    Yes, the low-loss header is larger than what is needed and we may use a smaller one.
    However, I am still unsure when an ASME low-loss header is required.
  • Zman
    I am not familiar with Canadian codes.
    Perhaps @Henry would know.
    Albert Einstein
  • Henry
    Henry Member Posts: 998
    The provinces are the AHJ. Loss headers are are not required to be ASME in Canada.
    Henry
    hot_rod Member Posts: 27,385
    They do need a CRN number. I think if it as the CRN it also has ASME, don't quote me on that.
