No cool
Insufficient cool.  ambient 80°, wet bulb 72, dry bulb 66, superheat 18° sub cool 9 approach 7, amp draw low, return 73 supply 64, 145/300. 410 A
    EBEBRATT-Ed Member Posts: 20,646
    Your amp draw is low which suggests a damaged compressor that is not pumping like the compressor is 1/2 working.
    mattmia2 Member Posts: 17,673
    edited June 2021
    What about noncondensibles? shouldn't the high side pressure be about 250 with an ambient of 80? or maybe a bad cap on the condenser fan so it isn't running at full speed
    edit:
    er i only partially read a post on checking for noncondensibles. not really sure what the high side pressure should be.
    Well, not sure here but i'm not ready to condemn the compressor yet.
    pecmsg Member Posts: 7,359
    Make
    model
    a little history helps also.
