air handler filter
Schvenzlerman
Schvenzlerman Member Posts: 41
Our SpacePak air handler uses a 14x30x1 filter. Okay, I just read some info online. Apparently, an inexpensive $2 fiberglass filter is a MERV 1 through 4. We don't have pets or allergies. Does anyone recommend higher than a MERV 8?
    pecmsg Member Posts: 7,359
    MERV 8 or less
    EdTheHeaterMan Member Posts: 12,583
    MERV 8 or less is great advice, and there are some pleated filters with that rating. That is what I gave my service agreement customers at no extra charge on maintenance agreement visits.
    The fiberglass filters are there to protect the motor only. A wet evaporator coil can trap more dust than those do. Go with the MERV 8 even if you need to order them on the internet because no one has them in stock locally. (but they are better than nothing until you bet the one you want.)
