Bosch IDS Heat Pump Thermostat
@Ironman, and others who have experience with this system, what is a good thermostat choice?
My daughter is having a 3 ton & 4 ton system replaced next week in the Phoenix area. The local contractor is suggesting the Honeywell T6 (th6320wf2003). It seems like a good choice, but other suggestions appreciated.
Thanks,
Tim
Winter Park, CO & Arvada, CO
  • Ironman
    Ironman Posts: 7,967
    That will work fine, but with a modulating unit, it needs to be set on one temperature and left there. Using setback, or running the stat up and down, will conflict with the logic of the unit and actually use more energy.
    Bob Boan
  • Tim Potter
    Tim Potter Posts: 274
    Thanks Bob, they are a set & forget family for sure. thing else you use with these systems?
    Tim
