Help Choosing new boiler
ten10ten
Member Posts: 5
Hi, I'm buying a new boiler for my house and I received 5 quotes from 3 different companies for new boiler with x being about 1.5-2 times the cost I was anticipating paying (no reason - just googled it).
Company 1 (company has 5 years parts & labor):
Boiler Option: Cost = 0.96x PurePro 59kbtu natural draft boiler with 50G Heat-Flo indirect hot water tank
Combi Option: Cost = 1.01x IDEX155C
He was pushing the combi but gave me the other quote when I requested it. He asked about chimney lining and said it would be extra to line the chimney. I said I thought it was lined but wasn't positive (as they had redone the whole house, electrical, etc etc at the time old boiler was bought - I don't think they would have not lined the chimney).
Company 2 (company has 2 years parts & labor):
Boiler Option: Didn't give me one as it he said it cost about 1.17x (guess he thought I would choose cheaper option?)
Combi Option: Cost = 1.02x Lochinvar NKC150N
This is the only company that did a heat assessment, the other 2 didn't. This guy was measuring windows and reviewed the whole house, asked questions about storm windows, etc.
Company 3 (company has 1 year parts & labor):
Boiler Option: Cost = 0.96x Purepro Advantage Gas Boiler AGDV3-HN 60 BTU w/ Bradford White Indirect Hot Water Heather SW-2-40-L 40G
Combi Option: Cost = 1.09x Bosch Greenstart 131 Gas Boiler & On Demand Hot Water KWB35
I told him I wasn't liking what I read about combis and he said that he felt the regular boilers lasted a lot longer. He mentioned that although he could use my chimney as it appeared to be lined he wasn't sure how good shape it was in so he recommended a separate vent to outside (no extra charge) because it would also pull air in - he mentioned the amount of air available in the boiler room (which is very small) might not be enough to pass inspection.
My local utilities also have a combi rebate that will be about 13% of the cost of the unit.
After reading about combis, I'm concerned about a few things but the main 2 things being I don't know how old my piping is (my house was built 1900) and I feel that they don't last as long. Even though only 1 of them did any type of heating assessment, the #s for the regular boilers seem close (maybe a little high) based on what I've been reading.
I'm leading toward the non-combi from Company 1 - all prices were similar but this one had the best parts & labor warranty, but not sure if I should get more quotes and thoughts about whether I should use my chimney or request outside venting.
I live in a ~930SF house with 3 heating zones. It's well insulated with only 1 drafty window that's being replaced. Please let me know if any other information would be helpful. Hoping for some feedback because this is all new to me! Thank you.
If it were me I would use a standard boiler and an indirect. and I would use a Peerless or Weil Mclain. But that's just my opinion. I would also line the chimney with a stainless steel liner (versus aluminum) if you are going to stay in the house for a while.
Get a certified chimney sweep to do this
An indirect with a stainless steel tank is usually better depending on your water quality0 -
Three zones what type of radiation ? Radiator or copper tube base board . What is the heat loss of the house ?
Hi, it's baseboard. Unfortunately the 1 person that did the heat loss calculation didn't share it. I have not tried to do it myself. I don't know anything about the insulation beyond that my house holds in heat very well. I am hoping to have an energy audit soon but the program I signed up for is on hold. I think when I tried different estimators I estimated my need to be about 45k plus I'm hoping for an addition someday.Big Ed_4 said:Three zones what type of radiation ? Radiator or copper tube base board . What is the heat loss of the house ?0 -
Just a few thoughts... first, the only way to properly size a modern boiler for hot water heating is to actually do a heat loss calculation on the house. Walking around and observing is a step in the right direction, at least... but since heat loss calculations are so simple -- and so critical -- one would think...
Oh well.
Second, I'm not a fan of combis. Once in a while you have a house and plumbing where the right size combi for the heating is the right size combi for the domestic hot water. Once in a while. I prefer either a separate water heater or an indirect. Both approaches work well.
Third, warranties are all very fine. However, this isn't a car, nor yet an iPhone. Quality equipment to begin with is always a good thing -- but a quality job of installing it and getting it set up properly is even more important. Most of the things which a boiler should need for the first decade or two aren't covered anyway -- annual service and maintenance.Br. Jamie, osb
Thanks, yeah, I didn't even realize what the person was doing was heat loss calculation until I looked it up after reading it above. It's not something I've heard of until this process. Both the 1st and 3rd companies are very highly rated which is why I was leaning to the 5 years vs the 1 year. I will of course do my yearly maintenance. It's not quite clear to me which equipment is quality which is why I posted and asked about the above options and then asked if I should get more quotes. I have tried to research some of the individual units (not all yet because last quote just came in) but haven't had much luck with finding reviews.Jamie Hall said:Just a few thoughts... first, the only way to properly size a modern boiler for hot water heating is to actually do a heat loss calculation on the house. Walking around and observing is a step in the right direction, at least... but since heat loss calculations are so simple -- and so critical -- one would think... Oh well. Second, I'm not a fan of combis. Once in a while you have a house and plumbing where the right size combi for the heating is the right size combi for the domestic hot water. Once in a while. I prefer either a separate water heater or an indirect. Both approaches work well. Third, warranties are all very fine. However, this isn't a car, nor yet an iPhone. Quality equipment to begin with is always a good thing -- but a quality job of installing it and getting it set up properly is even more important. Most of the things which a boiler should need for the first decade or two aren't covered anyway -- annual service and maintenance.0
