Looking for replacement suggestions for an old Coleman propane wall heater
kemiller
Member Posts: 1
in Gas Heating
I have a cabin with an old Model 68 Coleman propane wall heater (non-electric, 35,000 BTU). I was hoping for any suggestions on what to replace it with to minimize the work to fit a new one in. The walls are 2x4 construction and the existing heater vents out the wall.
It's even available from Home Depot...
https://www.homedepot.com/p/Rinnai-EnergySaver-36-500-BTU-Vented-Propane-Furnace-EX38CTWP/306653485
Works very well, reasonably quiet, and there is a kit available to convert it to run with a standard wall thermostat if you want it to (contrary to some of the comments)
It does need electrical power, if that's a problem...Br. Jamie, osb
Look at these products https://cozyheaters.com/full-line-spec-sheet/
