Kumo Cloud Zones Overheating
Papley
I have a Kumo cloud account with 5 Mitsubishi heat pump units. When they are turned on, sometimes a zone will keep heating well beyond the temperature set-point. I wake up drenched in sweat. The installer, a certified Mitsubishi installer has no idea what to do. They did tell me that their Mitsubishi rep tells them Mitsubishi is having ‘problems’ with the Kumo Cloud app, but I’m able to get no further information. This was working a few weeks ago, but it’s been messed up for weeks. Fortunately I still have an oil heat backup system so I just turned off the heat pumps.
Does anyone have any ideas?
Can you control the Mitsubishis locally? Take the cloud out of the picture? If so, determine whether the problem is with the Mitsubishis themselves (unlikely) or the cloud based app (very likely indeed). If it's the latter, good luck. The odds of coming up with a simple fix are between slim and none. If it's the former, your installer should be able to find and fix the problem --but so long as you have the cloud software playing tricks you're not going to get anywhere.Br. Jamie, osb
I’ve installed 70 or so, haven’t heard any issues. Maybe delete the app and reset the whole kit and caboodle.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
