BXX Heating Oil Disclosure?
Most older equipment isn't rated for much more than 5%. Newer Carlin & Beckett's and their associated pumps are rated for up to 20%.
Make sure the gaskets they are using are also bio-rated.
There's most likely no law to tell you the % yet, unless your jurisdiction mandates a minimum % of bio content.
But ask your oil company. Tell them you want no bio, if legally allowed.
I will tell you one refinery where I load, if you loaded 2% or 3% bio, it would state on the load ticket that the product may contain up to 5% bio.
The problems you may see would be leaking from seals, which in turn could be a vacuum leak, losing prime and locking out your burner.
Also bio will clean your oil tank and send it to the filter and pump strainer and eventually the nozzle.
But for my customers, after the first couple of years that problem subsided.
You won't want bio heat in an outdoor tank, without additives, nor do you want to store if for long periods of time without treating it.
But troubleshooting is troubleshooting. Many techs just want to blame bio without doing their due diligence.
Now if your delivery company gets all their fuel from one refinery or tank farm, they can easily provide you with a cut sheet of the product, where the bio stock comes from, etc.
This is why I recommend a full service provider for oil and service, even a small company like mine. The tech can't blame the fuel if their company delivered the fuel.There was an error rendering this rich post.
5 -
I'm surprised oil burners don't have to run DEF systems on their systems like diesel trucks now do. I wouldn't be surprised if this isn't mandated in the "New Green Deal". They did it to wood burners.0
There's a world of difference between combustion conditions in a diesel engine -- which produce various nitrogen oxides, for which DEF is used, together with catalytic converters and EGR systems -- and continuous combustion boilers (or, for that matter, gas turbines) -- which produce very little, relatively speaking.bucksnort said:I'm surprised oil burners don't have to run DEF systems on their systems like diesel trucks now do. I wouldn't be surprised if this isn't mandated in the "New Green Deal". They did it to wood burners.
Or get condensing oil equipment that's reliable on the market. They have it in Europe, I think we only have one decent one here.
I've spent more money then I care to think about on the EGR systems on my oil truck. I remember the truck dealer telling me companies were buying up all the pre DEF chasis, even if they didn't need trucks built to spec because they knew the DEF & EGR were going to be a nightmare.
Although I'd have to admit on my 2015 KW, the inside of the exhaust pipe is clean, no soot at all, and when I hold my personal CO monitor up to it, barely registers.
That's my mantra, have to use it way too much on Alan's FB page.Robert O'Brien said:"Many techs just want to blame bio without doing their due diligence." Amen!
True. But the soot and sulfur allowed to be burned in boilers and put in the air is scary. I guess it was easier to enforce EPA standards on trucks instead. Low sulfur for trucks is 15 PPM sulfur while #2 is anywhere from 3000-15K sulfur. Blending in bio brings those numbers down. When they first started pushing bio in MN trucks were puking all over. They had a 5% mix and who knows if people were selling 10% or more dilution.Jamie Hall said:
I can find out easily what the mix is for my oil truck. How can home fuel places get away with whatever mix they want to push off? They want to push 15% alcohol gas on us. It's bad enough at 10%.
They allowed a fat rendering plant in my town to expand 15 years ago to make bio. The plant stunk before and now it's worse. But it's cleaner! I'm just glad I live on the other side of town.
https://www.edf.org/sites/default/files/10071_EDF_BottomBarrel_Ch3.pdf0 -
" How can home fuel places get away with whatever mix they want to push off? ". Answer: they can't, at least around here, @bucksnort . It's ULSD or nothing. Most dealers do put some bio in as well, and it doesn't cause problems -- on newer equipment which has been and is kept in good order. Like ethanol in gasoline, however, it can and does cause problems for older equipment.
O course, I've never been quite certain of the trade-off between using what could be food -- there are a lot of kind of hungry folks in the world -- to fuel conspicuous consumption, but that's another matter altogether.Br. Jamie, osb
The sulfur limit is 15PPM for both on/off road diesel and heating oilbucksnort said:
True. But the soot and sulfur allowed to be burned in boilers and put in the air is scary. I guess it was easier to enforce EPA standards on trucks instead. Low sulfur for trucks is 5 PPM sulfur while #2 is anywhere from 3000-15K sulfur. Blending in bio brings those numbers down. When they first started pushing bio in MN trucks were puking all over. They had a 5% mix and who knows if people were selling 10% or more dilution.Jamie Hall said:
https://www.edf.org/sites/default/files/10071_EDF_BottomBarrel_Ch3.pdf2 -
Missed the 1 in front of the 5, thanks. Yes, more and more states are mandating Ultra low sulfur to 15 this comes at a cost as truckers found out years ago. Diesel was always cheaper than gas and the sulfur kept the injection pumps happy. Maybe diluting straight fuel oil with bio is an attempt to cocktail a mix to meet these 15 ppm mandates. Is it California that wants to eliminate new gas lines because wait, NG is dirty. Well if NG is dirty, fuel oil is porn. And what cancer happens in California soon spreads to the rest of the country. If they got everybody keyed in on 15PPM why not go to 5 or 2 PPM?Robert O'Brien said:
https://blog.smarttouchenergy.com/ultra-low-sulfur-heating-oil-and-premium-fuels#:~:text=Normal high-sulfur heating oils,as little as 15 ppm.1 -
The difference between 15PPM and 5 PPM is 1/1000th of 1%. The objection to fossil fuels is carbon output not particulate output.bucksnort said:
https://blog.smarttouchenergy.com/ultra-low-sulfur-heating-oil-and-premium-fuels#:~:text=Normal high-sulfur heating oils,as little as 15 ppm.3
