Is this a main line steam vent of some kind
Here are some pic's of a piece on the condensate  return line,
    EBEBRATT-Ed Member Posts: 20,236
    You need to stand farther back so we can see. That looks like a boiler return trap. The street elbow on top is your air vent. I see some cross over traps.
    That is a vapor system. What problems are you having? You have to run that at very low pressure.
    Others that know more about vapor will comment @Jamie Hall
    Jamie Hall Member Posts: 27,397
    I'll comment quite happily -- when I can see more of the system. And get a better idea of what is connected to what...
  • JUGHNE
    JUGHNE Member Posts: 11,554
    Floor to ceiling shots of piping, several sides would be good.
    Steamhead Member Posts: 18,528
    edited February 2021
    Might be an air trap rather than a return trap. There may have been a check valve installed in that street 90 to hold vacuum, which worked quite well when the system was coal-fired.
    Have you found any manufacturers' info on that unit, or anything else on that system? Where is this system located?
    Consulting
