One thermo jumpered to second thermo contact on my switching relay panel?
uhehs
Member, Email Confirmation Posts: 1
Hi. I have an ARGO ARM-4p four zone panel. Right now, each zone and each circulator has its own thermostat. If I want to get rid of one thermostat (taking down the wall altogether), so.......... can I run jumper wires from the Zone 3 thermo connections on the Argo panel, to were Zone 4 thermo connects to the panel, to then operate Zone 3 and Zone 4 simultaneously from one thermostat? Thank you in advance for your help.
Sure you can.0
Don't worry about controlling the temps. That why Burlington Coat Factory sells coats.
The reason was that you had 2 isolated zones, but with the wall gone you will now have one zone operating from 2 ZVs. Keep the thermostat that most accurately records the room temp unless, of course, one is on the wall you remove.0
