Shorter lengths of Pex-al-pex?
Blvd
Member Posts: 15
I need to move a radiator and due to the tricky routing, I’m planning on using 3/4” pex-al-pex. Problem is that I only need about 12’ of it. I can’t find anywhere that sells lengths shorter than 300’ — anyone know of options?
You can buy straight 20' lengths of HePex, maybe use that.Bob "hot rod" Rohr
Living the hydronic dream0 -
From what I’ve read, it seems pex-al-pex is the most appropriate — honestly not sure why since in the past, I’ve used he-pex for infloor radiant. Radiators seem like a similar application. Only difference seems to be higher operating temperature for radiators, but the specs for he-pex appear to match pex-al-pex.[EDIT] just did some more reading and it seems oxygen barrier pex would be perfectly fine to use in this application. Thanks for the inspiration, Bob.0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
