Copper fittings
@Youngplumber thank you!!0
This is the easiest https://www.supplyhouse.com/Elkhart-30346-1-x-1-1-4-Copper-x-Male-Adapter
If you can find it locally you can use a 1 1/4 MPT to sweat and a fitting reducing coupler."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
@Youngplumber What made you decide to pipe an air scoop? Have you considered using a spirovent type of air eliminator?
@Youngplumber was just answering a question for me! Does people not read the thread first lol
@STEVEusaPA what do you mean paper weight? Lol if the air separator is no good I can take it back and just get a caleffi or spirovent if that would be better?0 -
You will get better performance with a microbubble separator.jgaudet said:@STEVEusaPA what do you mean paper weight? Lol if the air separator is no good I can take it back and just get a caleffi or spirovent if that would be better?
Albert Einstein1 -
Ok I'll take the air separator back, would you recommend a caleffi or spirovent or they both about the same effective?0
Ok I'll check at a few spots tomorrow0
My favorite is the B&G IAS.... still a dumb piece of cast iron, but much more effective than "air scoops", cheap and no maintenance. I used the fancy stuff at one time, but prefer simplicity for reliability and ease of maintenance. It much better matches my preference for simple CI boilers. I've done my share of high tech and have learned there may be a better way.
To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Same here. I have a 1.5" B&G IAS in my system with one of their 3/4" vents. Found it on ebay as an NOS item for very little money, and have been very impressed with how well it works.The Steam Whisperer said:My favorite is the B&G IAS.... still a dumb piece of cast iron, but much more effective than "air scoops", cheap and no maintenance. I used the fancy stuff at one time, but prefer simplicity for reliability and ease of maintenance. alt="" />
The failure on air purgers is the float style vent up top not the body. The vent mechanism is pretty much the same on the IAS, EAS or the micro-bubble style separators, a float and needle valve of some sort.The Steam Whisperer said:My favorite is the B&G IAS.... still a dumb piece of cast iron, but much more effective than "air scoops", cheap and no maintenance. I used the fancy stuff at one time, but prefer simplicity for reliability and ease of maintenance. It much better matches my preference for simple CI boilers. I've done my share of high tech and have learned there may be a better way.
Really the only difference is the media inside that collects the microbubbles on the high performance coalesing separators.
Unless the fluid has a low ph or lots of crap, what are the failures in microbubble separators.
If a system has enough crap to plug a air separator, other problems need to be addressed.Bob "hot rod" Rohr
Living the hydronic dream1 -
I've found that properly set up piping really doesn't need a micro-bubbler. Tests I've read have shown that after a couple of passes, there is no gain in performance on a typical heating system. And when the vent does go bad, any old auto vent will work for only a few bucks instead of the built in proprietary vents used on most Micro-bubblers.To learn more about this professional, click here to visit their ad in Find A Contractor.1
i suppose if you wanted to be particularly cheap about it, closing the cap, removing the guts and a 1/8" npt tap would get you there.0
In a pinch, there lots of alternatives when you have just a standard thread connection to tie into.To learn more about this professional, click here to visit their ad in Find A Contractor.0
I have used the regular air scoops with a "spiro top " vent on it works pretty good.
Bet vent is a buffer tank or LL header
no moving parts 0 -
None of the separators have moving parts. All of the automatic vents, weather it is on a microbubble reabsorber or a buffer tank, have moving parts.EBEBRATT-Ed said:
no moving parts0 -
I think the microbubble seps really shine on projects where clearances are tight. They remove air much more quickly as well.
That being said I see the old air scoops installed and working perfectly all the time."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
The microbubble scrubbers will remove air from the water so more air can absorb in to the water from pockets that neither got bled or purged or are circulating so it will do a better job of removing the last trapped pockets of air, especially on this system there there isn't a section that is both hot and on the suction side of the circulator.0
Mattmia2...The testing I've seen has shown that that's not true for most ( if not all) systems. It will take a few more passes for the older types to get there, but once the system stabilizes, either type will provide the same oxygen levels in a system.To learn more about this professional, click here to visit their ad in Find A Contractor.0
I ended up keeping the air separator I'm going to give it a try, I just installed it today so I can't say how well it's working yet. Time will tell!
So, the local hardware store didn't have that reducing male adapter. Not surprising. It's more of a plumbing wholesaler item.
The setup you have will work fine.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
@Alan (California Radiant) Forbes I wasn't holding my breath that they had the proper reducing adapter ( good thing) lol but they did have parts to make it work at least!0
OMG!!!!!! The reason that is in ceiling?0
Well when I bought the house there was an automatic air vent in that spot it's the highest spot in the system, so I decided to put the air separator there also cause I still hear a bit of air running through my circulator the odd time! I'm not sure who set everything up but at least I have heat! going to do a major overhaul on it this spring.0
It would be interesting to pipe a microbubble separator next to a scoop style purger, run the system for a day with the microbubbler caped off. Then open and see if additional air comes out of the microbubbler.
I've built clear plastic versions of both and you can clearly see micro bubbles flowing trough the scoop type purgers.
Within a few passes all the micro bubbles are removed with a coalescing media.
At Caleffi we have done lab testing on most every type of vent, it is a very definable test and result.
There is no technology inside a scoop purger to remove air micro bubbles, entrained or dissolved air, it will just collect on boiler surfaces.
Perhaps in cast iron boilers those tiny bubbles collect in high points or evacuate out at a high vent on the boiler block.
Microbubble style do not need to be at a high point like scoop style to do a good job.Bob "hot rod" Rohr
Living the hydronic dream0 -
@hot_rod that actually would be a great idea to try and I actually could be the one to do it because when I do my overhaul on the system I am going to installing either a caleffi or spirovent. I wouldn't mind piping it beside the purger just to try. Only thing with that theory with them side by side what if most of the air favors 1 side over the other! It might be better to close the cap on the air vent on top of the purger for a day or 2 and see how much air comes out, then remove the purger and put the caleffi in its spot and close that cap for a day or 2 and see if it has more or less air trapped!0
We have a pretty extensive flow testing lab. We do a lot of testing in our lab of different designs. We can very accurately measure the air that we pump in and what comes out and the time. We also flow at very high FPS to see how well the microbubblers work when over pumped, also.
Not much air comes out of a ramp style purger at 8-10 fps, it blows right throughBob "hot rod" Rohr
Its curious that your testing revealed something opposite the testing I had seen previously...that over time standard air separators remove just as much oxygen from the system as microbubblers. Microbublers just did it faster. In your testing, did you run the B&G IAS models.... they are not air scoops.To learn more about this professional, click here to visit their ad in Find A Contractor.0
.0
Looks like it has a tapping on the bottom for the expansion tank:
https://www.supplyhouse.com/Caleffi-551003A-3-4-NPT-Female-DISCAL-Air-Separator0 -
That's what I thought they all had a tapping for an expansion tank! I was about to buy this one on eBay but it don't have the tapping on the bottom is it a knock off version?
- 16.2K Strictly Steam
- 52 Job Opportunities
