Trane Mercury seal or KMC info wanted
JonByk
Member Posts: 3
Does anyone have any information (drawings, patents, pictures) about turn of the century steam vacuum systems that used mercury? Thanks to this resource I was able to find some info on the Trane Mercury Seal, but I am searching for a schematic that shows how big these units were, and how much mercury they contained.
A plumber I know was a installing a new steam boiler and when he pitched the return line a large amount mercury spilled out of the pipes. The amount of mercury that spilled was much more than in a thermostat or switch. The mercury spill has created quite the headache for the homeowner, but the cleanup is currently underway. We are trying to gather as much information about these systems and assess how common they were.
Any information on these systems would be much appreciated! Thanks!
-Jon
-Jon
Odd that it was in the return pipes. The mercury was usually quite safely contained in whatever gadget was used -- but it wouldn't be the first time by a long shot that someone who didn't know what the gadget was tipped it and spilled the contents.
In answer to "how much", depending on exactly what gadget it was, it could easily be upwards of several pounds.Br. Jamie, osb
Yes, someone definitely could have spilled it. But it is also likely that depending on the construction of the device, that mercury escaped into the steam lines as vapor and then condensed out as a liquid in different part of the system. One of terrifying physical properties of mercury; it is constantly vaporizing, even at room temperature (imagine dry ice). As the ambient temperatures rises it vaporizes at an exponential rate, but unlike dry ice once the temperature drops it will condense back to its liquid form. If the device got warm or hot, it is certain the mercury vaporized at an astonishing rate and more than likely is deposited in all the piping and radiators.0
A search of the Internet Archive produces 17 hits. I don't know if they have the information you want. https://archive.org/search.php?query=%22trane+mercury+seal%22&sin=TXT&page=50
Those system where not steam but gravity hot water and the mercury I believe was contained in one chamber and assisted in increasing gravity flow . I have never heard of a steam system using mercury are you sure your plumber knows what type of system he has in front of him . Quite possibly a Honeywell unique ? Do the radiators have a single inlet which has both a supply and return piping if so that.s a gravity hot water system and high probability that it was a Honeywell unique gravity system w a heat generator which was located in the basement and usually a open tank in the attic .some one may have stirred it up in a attempt to flush or bleed system or when they draining . I have know idea how much mercury they contained but I guess it s a issue now . I have never seen a unique that was steam either , unless I’m completely wrong that system ain’t steam you better have the plumber take a closer look . I ve seen these and worked on them but the generator and the open expansion tank was long gone and had been converted from gravity Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
I might add to @clammy 's remarks... even if this was a steam system, such as the Trane you mention, the mercury should never have been heated enough to migrate, at least not is any significant quantity.Br. Jamie, osb
Guys, there were steam systems that used mercury pots, through which they vented air to produce vacuum. It was not limited to hot water. Trane and KMC are examples.Retired and loving it.0
That's what I was thinking, @DanHolohan , but weren't they set up so the mercury should never have seen steam?Br. Jamie, osb
Yes, Jamie, but someone may have power-washed the piping on a boiler replacement and moved the mercury. That’s what I suspect.Retired and loving it.0
Wouldn't surprise me a bit...DanHolohan said:Yes, Jamie, but someone may have power-washed the piping on a boiler replacement and moved the mercury. That’s what I suspect.
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
