Replacing White-Rodgers 1e30-910
kate_g
Member Posts: 1
I inherited a very old mercury thermostat with my condo, and I'm trying to replace it with a basic programmable model. It's a heat-only system. I have 2 wires–a red wire connected to the R5 terminal and a white one connected to the 4 terminal. My best guess is that R5 -> R and 4 -> W but I can't find anything definitive. Is there any way to confirm this without tracking wires down to the boiler (I am not able to do this)?
That will work. I'm a bit puzzled, though, as the thermostat you mention -- the White-Rodgers 1e30-910 is not programmable, and will not do anything the old mercury thermostat (which, by the way, is far more reliable, accurate, and precise -- much better thermostat than the White-Rodgers). Is that the model you meant?Br. Jamie, osb
The WR 1E30-910 is your old tstat? yes.
If so the 2 wires are the R & W you are looking for.
Be sure to get a new one with batteries. Or you lose the programing and screen in power blink. The Nest, for a boiler, is probably not recommended by anyone here.
I would go with HoneyWell Focuspro series. I think it is the 6000 series.
Large numbers, gives both actual temp in room and your desired setting.
Go to SupplyHouse.com for selection.1
- 120 Geothermal
- 169 Indoor-Air Quality
