Utica boiler question
Mike944
Mike944 Member Posts: 3
edited December 2020 in Gas Heating
Hello everyone, first timer here with a question on my Utica boiler and a new radiant heat install with a second circulator. I have a 5 year old Utica SVB-4 boiler with an Argo AZ-5 zone controller, 4 baseboard zones in use with one circulator. As I understand (and the way the boiler currently functions) when the thermostat calls for heat on any of the 4 zones the circular starts and then the boiler fires. I would like to install a second loop with a second circulator for radiant heat. Assuming I use a Taco SR501 to control the second circulator how do I run the XX wires from the SR501 back to the boiler? If I tie them into the existing TT wires on the boiler this will start the first circulator, I just want to enable the boiler to fire and let the second circulator take care of the radiant heat. Is there a spot on the Honeywell control board model S9361A2070 where I can attach the XX output of the SR501to give a permissive for the boiler to start without starting the first circulator or will the boiler start based on lowering temp in the boiler once the radiant heat circulator starts(pretty sure I need a permissive to let the boiler start)? Still looking into it and I could use the 5th zone on the AZ controller but I’ve heard radiant works better with its own circulator. Thanks for any help you can provide.
Mike
  • Ironman
    Ironman Member Posts: 7,902
    What type of radiant? Slab? Staple up?
    Bob Boan
  • kcopp
    kcopp Member Posts: 4,663
    You will need a separate sr 502 relay... this will now control both circulator pumps.
  • Mike944
    Slab
    HVACNUT Member Posts: 7,411
    The existing circulator is wired through the boilers circuit board, not the Argo relay?
    The existing circulator can be wired to "end switch 2" on the Argo. "End switch 1 should already connect to the thermostat connection on the boilers board.
    Then the SR501 can be used. Wire Com 5 and N.O. 6 in parallel with "end switch 2" to to thermostat connection at the boilers board.
    Mike944
  • Ironman
    Mike944 said:
    Slab
    If a slab, then you need a smart mixing device to provide the right water temp to it. You can't use the same temp that's going to the baseboards and this changes the control strategy.
    Bob Boan
  • Mike944
    Ironman said:
    Slab
    It’s on the list👍
