W/M Aquabalance WMB120 combi A02 code-False flame indication, HELP
andymar
andymar Member Posts: 25
My gas Weil McLain Aquabalance 120 WMB120 combi is two years old. I have been getting an A02 false flame indication error code with a hard lock out. I initially cleaned and re-installed the ignitor electrode. Problem continued. I replaced the part and again the problem persists. After re-setting the unit will operated both DHW and heat for 12 to 24 hours, cycling on and off, then go into A02 mode. Please help.
    It's not the ignitor. The cad cell is probably seeing light when it shouldn't -- or is defective of misadjusted.
  • andymar
    Thank you for your response. I do not see a cad cell listed on any diagrams in my manual. Is it possible the cell is included in any other part? Is this something that can replaced as a homeowner without specialized tooling or gauges?
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,595
    There isn't one on gas units,only oil
