Boiler issues!!!
Jory
Member Posts: 1
So I'm completely perplexed by my system. I have twin Veissman Vitocrossal 300 CT3 89 gas fired condensing boilers. They are not making good heat. I have no leaks on the closed loop, I'm not making up water on the loop. I have vented everything, no air. Pumps are showing 100 gpm at 42/ft head respectively. In short, I am at a loss. Could corrosion on the water tubes cause this or should I be looking somewhere else?
This sounds like a controls issue. That being said, unless you are a very experienced commercial boiler tech, you will want to continue with great caution. What you are looking at is a very large State of the Art boiler plant, be safe..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
