Finally...a Skim Port (picture).
AdmiralYoda
Member Posts: 798
My 37 year old pressure relief valve was installed horizontally (wrong) and all gunked up.
Installed a new one and put a proper skim port on it while I was at it.
Watcha think?
Watcha think?
pretty good. I'd get rid of the elbow so you can see the gunk getting floated out and have a better idea of the flow rate
That's what the Tee to the left of the valve is for. I can remove the plug on top to watch things float by.
Also a convenient port for adding chemicals if needed.0 -
Yep, I saw it, the tee is good
One just needs a lot of patience to use a 3/4” skim port...New England SteamWorks
newenglandsteamworks.com2
- 125 Chimneys & Flues
