replacement part - relay switch of L8148A
jsda77
jsda77 Member Posts: 19
Hello,
I think my L8148A unit has bad relay switch issue.
I want to try part replacement before entire unit replacement.
Does anyone know about the part information(part number, source, etc.)?
Thank you.
    Steamhead Member Posts: 18,625
    The relay in that unit is not replaceable by itself. Just replace the control.
    It makes sense to upgrade to an AquaSmart or HydroStat type control, as this will save some energy. And the cost is roughly the same.
    Consulting
    STEVEusaPAHVACNUTjsda77Zman
  • jsda77
    Dear Steamhead,
    Do you have any specific recommendations?
    Thank you.
    EdTheHeaterMan Member Posts: 12,442
    Your easiest change out is the Honeywell L7224U. This can be set up exactly like your L8148 control and it has ASI settings to reduce short cycling
    Once you have that control we can talk you thru the setup. That is my go to control for many reasons.
    jsda77
    edited December 2020
    The Beckett Aqua-smart control is similar but has additional energy saving features
    https://www.supplyhouse.com/Beckett-7610A0001U-AquaSmart-Boiler-Temp-Control-120V-Oil-w-Temp-ONLY-Sensor-120V-Burner-Circuit
    You will need additional accessories to use all the energy saving functionality
    jsda77
