Triangle Tube provides DHW, but no heat
We received two calls this week from homeowners, one that has a TT Solo and the other has a TT Excellence (combi). They have DHW, but no heat. I jumpered the thermostat connections at the boiler; nothing happens. Thumbing through their literature, I looked for a DHW only vs. DHW/heating setting, but found none. Also disconnected the outdoor sensor even though it was below 68F without any response from the boiler. Any ideas?
See page 16 - Top right of page for "shortcut" that was probably activated by accident
https://triangletube.com/getmedia/773a8c23-9f26-4a7e-ba4a-37d210d98fca/PS-Control-Supplement-5-MCBA.pdf?ext=.pdf2 -
Parameter 3 had a setting of "00", "Burner and CH Pump Disabled". Changed it to "01", "Burner and Pump Enabled" and the burner kicked on.
Ever since a power surge, the boiler was only heating DHW.
Thanks again, gentlemen!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1
- 133 Chimneys & Flues
