Copper risers...how big a deal?
in the middle of a major kitchen remodel and have access to 3 runouts and risers to small radiators in the kitchen and 2nd floor bath which i see have been laid out in 1"copper from a previous renovation. Its perhaps a total of 60 linear feet
Having read and researched I know that "near boiler" piping should never be a copper job...(re-did near boiler 6 years ago for this reason). Is it critical/important enough to spend the extra $$ now to replace these copper pipes. Will these risers/runouts create boiler issues in the same way that near boiler piping does?
forgive me if this is a hot topic but I Did a bit of searching and did not see a specific callout on copper risers... i
    Jamie Hall Member Posts: 27,519
    Probably not, provided they are free to expand and contract linearly. If they are restrained somehow, or if expansion and contraction of the longer straight pieces puts a twist on a joint, maybe.
  • BigRedSteam
    BigRedSteam Member Posts: 21
    thanks...any concerns with joints failing or corrosion in the boiler or mains from dissimilar metals ?
    Again, most likely not. Any dissimilar metal corrosion would be right where the copper joins the iron -- if any occurred at all.
  • Neild5
    Neild5 Member Posts: 203
    If you see any signs at any of the joints of hard water deposits I would replace all of it.
    EBEBRATT-Ed Member Posts: 20,397
    The copper risers will cause no issues as far as how the system operates.
    The problem is with expansion and contraction (copper expands more than steel) and puts stress on the sweat joints.
    If you have any sweat joints with no access inside the walls I think I would address those. If the joints are acessable I so they could be repaired in the future I would let it go.
    BigRedSteam
  • Pumpguy
    Pumpguy Member Posts: 806
    If not insulated, this would probably be the time to do so.
    luketheplumber
