Stuck in the middle of NCB-240E and NFC-175
Fifty BTU's per square foot is a high number. You must have limited insulation, 12 foot ceilings, lots of single-glazed windows and live in Fargo.
Do you really need to keep your garage at 68F when you want it heated? Lowering that temperature will bring your heat load down.
If you have multiple zones in your living and sleeping areas, the chance of all the zones being on at the same time is less than 100%.
How many people in the house? If you have lots of family or tenants and don't want to worry about ever being cold, go with the larger one. I don't know the boiler, but you may be able to de-rate it so it won't short-cycle.
I like to live dangerously, so I'd probably go with the smaller one.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
The garage (with uninsulated slab) and basement aren't in the 2600 sf number. 5 zones. Figuring the workshop at 60 degrees. House is 1950's, currently electric heat, fairly well insulated and I've sealed well. Upgrading the insulation is an ongoing process. Just my family of 4.
Thanks, all.0 -
If you plan on more energy upgrades, and considering some fudge to the high side in load calcs, I too would go smaller.
Where are you located? You could look up past weather data to see how often you are at or near design.
An example for upstate, NY.Bob "hot rod" Rohr
Living the hydronic dream0 -
I used John Siegenthaler's methodology from Modern Hydronic Heating to determine the heat loads... hence the over the top comment about "exhaustive"! Was like going back to school. I'm in Zone 6b in Western CT... local design temp is 9 degrees. We see that maybe 7 times a year? I tweaked the heat calc every which way to see how I could improve things. Being realistic, I think the 133k number is pretty accurate. I have a hard time overcoming the losses to glazing in my sunporch and the uninsulated slab in my garage. And realistically, I'm not going to improve on either of those in the near future given a number of factors. In 5 years? Maybe...
I appreciate the opinions!0 -
A little bit of window covering goes a long way to reducing a large glass load.
Pretty much all load calcs are based on Manual J. As such, figure a 10% CYA factor
But, as you discovered the data input is the key, infiltration being the hardest to "guesstimate.
Check with your utility, some offer cheap or free blower door test. That can really be an eye opener in an older home. A few cans of spray foam can really change infiltration.
www.dsireusa.org will lead you to any programs available for winterizing and upgrades.Bob "hot rod" Rohr
The problem with Mr Siegenthaler's methodology is no 2 houses are the same. In reality every system we install is a Custom System!jmatthewwest said:I used John Siegenthaler's methodology from Modern Hydronic Heating to determine the heat loads... hence the over the top comment about "exhaustive"! Was like going back to school. I'm in Zone 6b in Western CT... local design temp is 9 degrees. We see that maybe 7 times a year? I tweaked the heat calc every which way to see how I could improve things. Being realistic, I think the 133k number is pretty accurate. I have a hard time overcoming the losses to glazing in my sunporch and the uninsulated slab in my garage. And realistically, I'm not going to improve on either of those in the near future given a number of factors. In 5 years? Maybe...
Try a manual "J" Heat Load / Loss calculation. I think your actual #'s will come in much lower!
https://www.loadcalc.net/
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
