Boiler has me stumped....
If the expansion tank is actually a compression tank (no bladder), then drain it and and replace the relief valve. Then set the fill valve to 15 psi and bleed the radiator(s).
If it's a bladder tank, replace it.
You may also need a new fill valve.Bob Boan
As you already know, water expands when it is heated and contracts when it cools. The expansion tank needs to contain enough air to compress, in order to let the water expand to that tank.
That said, Draining an expansion tank may be misunderstood by many. You don't just want to let water out so the pressure gets to zero. Draining the expansion tank should more correctly be called "Adding Air" to the expansion tank.
Picture an expansion tank where all the Air was replaced by water. "Yes, it could happen". Now there is no room for the water in the boiler to expand. Now you remove the only air in the system, the air in the bathroom radiator. The boiler is cold and everything is full. You turn on the boiler and the water heats and expands and there is no place to go, SWOOSH The relief valve releases the excess pressure. all over the basement floor.
The first step is to Get Air Into "Drain" the expansion tank. See if that solves your problem.
I have a unique way to do this task. I have taught it to everyone who worked for me and I have explained it here
https://forum.heatinghelp.com/discussion/comment/1620527#Comment_1620527
Hope this helps.
1 -
1 -
While water does expand and contract with temperature - its not a large amount - and normally should not vary your pressure by more than a few Lbs.
While it may be just the expansion tank as per the previous posts; it may be another issue.
Trapped air in the system pipes that gets heated and cooled by the actual circulating water expands and contracts a lot more.
I'd eyeball your piping system and look for high points that don't have vents that could have trapped air in them.
I'm actually dealing with this issue myself as I just installed a 0-30 PSI pressure gauge on the system (with a new expansion tank) and I could see the pressure varying by several PSI based on a 20 F temperature change on the system. It is also obvious that the air scoop was installed in the wrong place by the contractor years ago (on the low point system supply (after the pump) - and the high point on the return piping would obviously trap air when the system is filled. Note my monoflow T system pipes are gently slopped upward about 1/2" for each side of the house. So the return pipe is about 2" higher when its piped back to the Low Loss Header.
I wish you the best on this,
Perry0
- 133 Chimneys & Flues
