Tank Fill Line Coupling
Galand
Member Posts: 1
in Oil Heating
My oil heating service, with whom I have a maintenance agreement, told me they had to remove the dresser coupling between the tank fill line and the tank in my basement to replace it with a "black" union and charge me $250.00 for that job.
This dresser coupling was installed with the tank about 10 years ago and looks perfect with no sign of leakage. They say that they cannot make further fuel deliveries until that coupling is replaced. Can anyone confirm that this necessary? I am in NY state.
That coupling is not to code in many places, but probably not all. You could check with your local building authority on that, though.Br. Jamie, osb
Yeah it should be changed out.
Check with the local authority that inspects oil tanks in your area. Probably should be changed. Oil truck pumps put out some decent pressure0
Better then 200 gallons in your basement ...
- 125 Chimneys & Flues
