Help
I have a Weil-McLain Blue bought it with the house supposedly from either the 60-70s The Coil went the company wants to replace the whole system. Should I fix the coil or should I get a new oil burner and indirect water heater.
looking at the system 2000 or peerless
  • Ironman
    Ironman Posts: 7,960
    edited September 2020
    We'd really need to know the condition of the system and boiler, but at 40+ years old, replacement should be considered.
    Also, an indirect and new boiler would probably save you 30%+ on fuel.
    If it's an oil fired replacement, I'd look at the Buderus G115 with a Riello burner. It's by far the best cast iron boiler made. It's 3 pass and very easy to clean. I wouldn't consider a pin boiler for oil.
    Bob Boan
    STEVEusaPA
  • STEVEusaPA
    STEVEusaPA Posts: 6,505
    Condition is important, so is comfort. I would also recommend a 3 pass or and Energy Kinetics.
    Never a pin boiler.
    The one issue with replacing the coil if bolts/studs get broken, very possible, the added cost may make the coil replacement more expensive.
    Probably better to just put that money into a properly sized boiler with indirect, or the EK.
  • Jellis
    Jellis Posts: 232
    Id say replace the boiler,
    good chance in additional problems showing up when replacing the coil with a boiler that age. The system 2K has my vote, great systems and great company to work with.
  • The old pin boilers were reliable, but fuel hogs in the spring summer and fall.  If you have a System 2000 installer in your area, that would be my first call.
  • Thank you everyone for your help
    EBEBRATT-Ed Posts: 21,113
    Weil Mclain Blue? a P68?
