K2 Not Heating
jzhao
jzhao Member Posts: 3
Hello there! I have a K2 combi, about a year old, and suddenly, it is not longer producing hot water! Haven't changed any settings but the boiler temperature dropped from the usual 170~ to 70~. Rate has gone to zero and no flame signal. Anything to do from my end before calling a technician?
  • jzhao
  • Zman
    Zman Member Posts: 7,614
    It never hurts to cycle power to the unit. You could also go through the menu and check error log.
    You more than likely need to call a tech. Checking the log might allow the tech to have the replacement parts to fix the problem on the first trip.
    Albert Einstein
    kcopp
  • jzhao
    Yes, went through the menu and looked through, just showing up as not firing/way below set temp. Can you clarify on cycling power to the unit? Sorry I am new to this
  • kcopp
    kcopp Member Posts: 4,700
    He means turn it off then back on....
