Magna3 Blocked Pump 51 Error Message
Hi All, we have a system installed with Magna3 50-180 in which the system is pressurized with water to 3 bar. Running at 100LPM at 12 meter pump head. It sometimes have problem with starting up the pump with Alarm Message "Blocked Pump (51)" show up. We had disassembled the pump, but found that the inside is clear with no debris and we even replace the DPS sensor. What would be the possible causes?
Thanks.
  • kcopp
    kcopp Member Posts: 4,700
    It could be air or dirt.
    HVACNUT Member Posts: 7,526
    Pics?
    Describe the system. Boiler, piping/sizes, zones, controls, emmiters, etc.
    pecmsg Member Posts: 7,281
    What did Tech Support recommend?
