Radiator steam traps
gh2538
Member Posts: 4
Looking for more info about these traps as I was unable to find any data in the books. The boiler we installed 18 years ago rusted out prematurely and as I recall this boiler always cycled on room thermostat and never reached 1.5 psi cutout....go figure LOL
Weighted check. The hole is for air and a bit of steam. The weight of the trapped condensate opens the check. The condensate level in the radiator drops. The weighted check cycles closed again.Retired and loving it.0
I love that offset, eccentric bushing.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Donnelly system, right? As shown in chapter 15 of Lost Art?DanHolohan said:Weighted check. The hole is for air and a bit of steam. The weight of the trapped condensate opens the check. The condensate level in the radiator drops. The weighted check cycles closed again.
Consulting0 -
It looks like someone drilled and tapped the end cap. The rococo border gives it away.JohnNY said:I love that offset, eccentric bushing.
No, that's actually an eccentric bushing. They actually did make bushings with fancy borders back then, both standard and eccentric. We might have a couple laying around at the shop.Hap_Hazzard said:
If we have to put something like that together now, we'll use a double-tapped oil tank bushing and plug the unused hole.Baltimore, MD, USA
Consulting1 -
Wow. I don't know what's more amazing: that they made bushings like that or that the installer would take the trouble to use a bushing that matched the style of the radiator.Steamhead said:No, that's actually an eccentric bushing. They actually did make bushings with fancy borders back then, both standard and eccentric.
- 125 Chimneys & Flues
