Boiler supply / return connections
CBRob
CBRob Posts: 291
edited March 2020 in THE MAIN WALL
The connection here seems to be one that is prone to leaking.
I've also seen different connections used here. Black iron pipe, copper and brass
Is there a preferred fitting here that is least likely to leak over time?
    hot_rod Posts: 28,493
    Is that a brass BSP to NPT adapter? Is that the leaks point?
  • CBRob
    CBRob Posts: 291
    Bob, I think it's just a 1 1/4 female adapter.
    The leaks I've been seeing are at the brass to copper threaded connection.
    This is one of the triangle tube boilers in the homes I manage.
  • DZoro
    DZoro Posts: 1,048
    I don't know what TT does different with there adapters but they have always been troublesome. Besides the fact that they make it 95% impossible to put 2 pipe wrenches inside that space to tighten them up.
    I always use a union Just because of the issue, and so many times one has a hard time sealing up the union. Tape, dope, repeat, tap toes together 3 times, sign of the cross, and maybe...
    D
    CBRob
  • CBRob
    CBRob Posts: 291
    Here is another, little bit different.
    Still a tri tube boiler
  • BillyO
    BillyO Posts: 277
    junk
    SuperTech
    cut them off and solder onto the copper.
  • Zman
    Zman Posts: 7,614
    Those really like to leak. I have suspected that the machining is off. Cutting it off and sweating would solve the problem, I wonder if it would create a warranty issue.
    I have used these with good success. https://www.supplyhouse.com/Elkhart-56686-1-CxF-Union-Lead-Free
    Albert Einstein
    CBRob
    If it is a Euro built connection they tend to over-think the NPT thread sometimes :) They machine a NPTF thread and it may not work so well with the fittings common over here, the standard NPT.
    On one of my own boilers I cut the copper tube up inside the cabinet, soldered a copper coupling and copper tube the length I needed. As Z mentioned it may void warranty.
    CBRob
