Gasmaster Boilers
Danscrew
Danscrew Member Posts: 130
Does anyone have any experience in programming (Solas controls) or trouble shooting a Gasmaster condensing Boiler?
That was installed in the 350.000 square foot Building i work in Soho section of NYC ? Gasmaster and there service rep have been unhelpful in correcting the problems. The Boilers were installed 2 years ago with constant problems. Attached is the boiler size. thanks Dan
https://www.gasmaster.ca/products/nx-series/nx-3000/
    EBEBRATT-Ed Member Posts: 19,577
    Never saw one but from what I have herd they are nothing but trouble
  • BillyO
    BillyO Member Posts: 277
    99.8 efficient. wow
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,509
    > @BillyO said:
    > 99.8 efficient. wow
    If they don't work, they are 100% efficient.
    BillyO
  • STEAM DOCTOR
    No heat exchanger maintenance.
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    In the right conditions Lochinvar Crest and FTXL are have to be close to 99%+ efficient. I was seeing 1-2F approach temps on flue vs return water at low fire at my lost job that had one.
    The way most engineers I;ve seen pipe them and pump selection, they are usually 86-90% efficient if I take th time ot adjust the reset curve.
  • B_Sloane
    B_Sloane Member Posts: 56
    I had a brief relationship with GasMaster 12 years ago
    what might you want to know ..??
