Boiler issue or no?
We have been having issues with our shower in both upstairs washrooms getting cold after a few minutes of showering. When i get out of the shower and run the sink tap there is hot water at both sinks and any other sink in the hose, but shower is cold. I thought it might have been a shower tap mixing cartridge at first but i replaced them in both showers and still having the same issue.
I have a Comet 145 oil fired hot water boiler.
I dont know much about the boiler and was wondering if it has anything to do with the boiler that is causing the issue. I also have the water temp setting on boiler set on 5. Not sure if there is enough info in this post for someone to diagnose my issue or not. Before i have to call someone in to look into this for me....Any help would be greatly appreciated.
    Jamie Hall Posts: 27,877
    Do you know whether your Comet is set up with an indirect hot water heater, or is it set up with the domestic hot water coil?
