Auto Vent No 67 Auto Bleeder
Gregory_2
Gregory_2 Member Posts: 30
edited January 2020 in Domestic Hot Water
Do I need to completely drain the system to replace? I have 3 story 1 zone house
and less that 5 lbs of pressure in the system. If I turn off unit can I replace without
draining the whole system?
the auto bleeder is at the top
TIA
    You may have to drain it down slightly to avoid getting wet.
    However, if you have a 3 story house with hot water heat, 5 pounds of pressure (I presume in the basement at the boiler?) is nowhere near enough. You should have at least 15 pounds pressure in the system when it's cold; check that before you work on that bleeder, because if it's really only 5 pounds when you crack that vent it's going to such air into the system and you'll have to purge the whole thing. At least you wouldn't get wet...
    Gregory_2
  • Gregory_2
    Jamie thank u. And yes that’s the issue I keep losing pressure and I think it’s the auto bleeder
    I had another thread going on this forum about it. Thanks
  • Gregory_2
    another quick question. should the old one come off by hand?
    and will I need dope or tape for the threads on the new one
    thanks for your help
  • SuperTech
    SuperTech Member Posts: 2,669
    It might come off by hand, or you may need a wrench. You can use either pipe dope or Teflon tape, or both of them together.
  • HomerJSmith
    HomerJSmith Member Posts: 2,793
    Why do you have such a large air vent on the third floor?
    Caleffi makes a hygroscopic air vent that is very good and in combination with their 1/8" NPT Male Service Check Valve allows changing the vent easy.
    https://www.supplyhouse.com/Caleffi-508013A-1-8-Automatic-Hygroscopic-Air-Vent
    https://www.supplyhouse.com/Caleffi-59474A-1-8-NPT-Male-Service-Check-Valve
