Short cycling
am7315
am7315 Member Posts: 2
Hello I have a question, I just moved into a house with a 96% hi efficiency that was recently installed by the previous owners and noticed that it was short cycling. There are four red flashes which is a open limit switch. I was able to clear error code by closing gas valve enough so internal temp of furnace was not high enough to trip limit switch. Question is, is this normal or should gas valve be opened all the way all the time?
  • am7315
    Is it ok to add a return vent near furnace on the return side?
    mattmia2 Member Posts: 16,757
    no and no.
    Jamie Hall Member Posts: 27,359
    and you need to get a competent tech. out there familiar with that particular unit to service it. Something is amiss, and those high efficiency units absolutely have to be serviced by someone knowledgeable on the particular make and model.
  • JUGHNE
    JUGHNE Member Posts: 11,549
    How is the air filter?
