lower boiler water ph
stevenknaub
Member Posts: 36
What is the best agent to lower ph inBurnham Independence Steam boiler? Using Rectorseal 8-way boiler treatment in my boiler water, my ph is 10 to 11. Seeking 9.5. Looking for a long term, long lasting ph lowering agent. Some say vinegar, I am all in if it is long lasting. Thanks.
You don't need to add anything to lower it. Just add less 8-way to keep it from going so high.
8-way like all the treatment makers, overstate how much to use (just like shampoo: wash, rinse, repeat) in order to sell more treatment.
Measure the ph of your tap water to see what it starts out as, then try draining like 1/4 of your boiler water and refilling then see where you are at.
When I add 8-way after a full flush (rare), I start with 1/4 of what they say to add, then I bump it up after that until I'm at the ph I want.NJ Steam Homeowner.
You got that right!!
If you over shoot the desired PH, drain some water and add fresh water to the boiler until you reach 8.5 to 9 ph.
excessive ph can cause a sudsing in the boiler which will cause an unstable water line.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
And as I know Jake knows, it's not just the waterline--it also causes what you see in my profile pic!NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el1
- 119 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
