Confused about verivalves and purpose...
Plewis
Plewis Member Posts: 1
edited December 2019 in THE MAIN WALL
Traditional water heaters on wall. Electric thermostat set to 74. All knobs on the heaters themselves are open. All heating units work, but... some randomly shut off after a few hours while others stay on. First question is what position should the verivalves be set to? Open or closed? Two, can these even be the culprit for units not staying on that can in fact reach can high heat... Some rooms are freezing as a result of these shutoffs despite others being very hot...
  • Zman
    Zman Member Posts: 7,611
    Can you post pictures? It sounds like you have steam radiators with a single t-stat. If so, you might try closing the valves closest to the t-stat and opening the ones farthest away.
    Albert Einstein
