WiFi thermostat with Weil Mclain boiler
Good evening guys. I'm trying to install a wi fi thermostat with my Weil Mclain boiler. I searched in the forums here to no vail. Any word on how to add a common wire for this boiler. I dont want a wal wart. Thanks.
    Jamie Hall Posts: 27,909
    Somewhere on or around your boiler there is a transformer. One terminal on the low voltage side is the common; the other is hot 24 volts. You need to identify which one is the common side and run your third wire from that to your thermostat.
    HVACNUT Posts: 7,746
    If you tell us the model of the boiler, we can better lead you in the right direction. If oil fired, 1 zone with a triple aquastat, it will need a separate transformer and an isolation relay. Most gas fired boilers, atmospheric or mod con will have an internal transformer you can use or a zone control board.
  • @HVACNUT
    I hope that's what I need to show so you guys can help me with this task.
    Thanks.
    @fabaze12 yes that helps but...
    Can you post a pic of the whole boiler from about 8 ft away?
    Steam or water boiler?
    We'll see if there's anything with a transformer you can use.
    7 sections? Really big house or oversized boiler.
  • @HVACNUT, its a 3 family. 1st and 2nd floor is about 2700 sq ft altogether. 3rd floor is about 450 sq ft but the lone radiator sits in a room about 150 sq ft.
    OK. You don't have a common on the system that can be used. The low volt from the thermostat goes directly to TT on the burner primary. A switching relay like a Taco SR501 will need to be installed by a qualified tech.
    On a side note, the boiler is rated at 2.00 GPH but I see on one service card the nozzle is 1.25 GPH. It's possible the pump pressure has been increased to bring it up but I would find out.
