Impedance of 0-10v control on HTP UFT-100
Does anyone know what the impedance of the 0-10v control input on an HTP UFT-100 is? I am trying to control it with a 0-10v output from a Crestron processor (the device is actually intended to be used with 0-10v dimmers). When I set the output of the processor at 100% I get 5 volts and some change with it connected to the boiler (so it heats to about 50% of the max water temp setting) but if I disconnect it I measure 10v. The measured polarity is correct. I am trying to determine if the new old stock control is bad or if the impedance of the boiler is too low. I have impedance specs for the control, I couldn't find impedance specs for the boiler. I could measure with a milliammeter as well. Is there something weird about the circuitry of the Crestron output that makes it not work right with how the boiler is referenced to ground?
    mattmia2 Member Posts: 17,474
    I got an answer, at least a theoretical one, from a crestron programmer. A dimmer works by the dimmer providing voltage and the control loading that source to the desired voltage, so i need something like a pull up resistor or a voltage divider off of the 24v dc crestron supply to make it provide 0-10v to the boiler. i will probably test the theory this weekend.
  • ratio
    ratio Member Posts: 4,264
    edited November 2019
    Never mind, I reread the first post.
    Now i want to know what your question was...
  • ratio
    I was going to say that a pullup to 24 volts doesn't sound quite right, but when I reread everything (after I posted, of course!), I saw where you implied that the output on your controller was a sink, not a source.
    IIWM, I'd look around for a schematic of something known working & work backwards from that. Or talk to someone who knows what they're doing. :smiley:
    This seems to work like a charm:
    ratio
