Tankless aquastat
keith123
Member Posts: 105
If repurposing a tankless coil on a steam boiler for space heating, which a Honeywell aquastat would you use
Separate heating zone is correct0
L6006 or L4006 in the aquastat tapping on the coil. Set at 180 or lower. This will keep the boiler from steaming on a call from the hydronic coil zone.
set up the circulator relay as indicated in the diagram
1 and 2 are L1 and L2 or common
T T is from the zone thermostat
jump 1 to 3
power circulator with 4 (power) and 2 (L2 or common)
1 -
Thank you sooo much !!0
